Most physical sparkying? | on ElectriciansForums
Discuss Most physical sparkying? in the Australia area at ElectriciansForums.net
C
chronyx
What in your experiene is the most physically demanding area of the electrical sector?
I've had a couple of jobs that were physically hard (Helping to wire mansions with huge ceilings, up and down 10 tread steps all day etc)
At the moment it's quiet and I miss being so active.
the worst experience i ever had was pulling a new 240mm 4c up to the new board under the davy cooper stand at motherwell football club myself! it's the only time in my life so far where i thought i was going to die!Apart from the shootin obviously bit that's another story!
Pulling large cables and i don't mean 16mm T&E.
Try pulling a 4 core 400mm SWA cable a couple of hundred metres, Especially when you then have to turn the cable to get the cores lined up on the final terminations, because there just isn't room to cross the cores....
That's what i would call Real Physical work for any man!!! lol!!!
owe yes, been there done that. its made me knackered just thinking about it!
I had to get 9 stitches on my head from trying to gland and dress a 4x240 swa into a chiller on the roof of a factory.Tight spot.
And before you ask where my helmet was,it was on the ground. Lesson learned.........
agree with sintra. Also, glanding and terminating larger cables ie 95mm2 and above is hard work, and requires thought, technique, and a little strength.
There is an alternative glanding system to the usual brass SWA screw glands. Using a ''Top Hat'' gland, normally used on MV SWA cable terminations. Time taken in glanding operation can be more than halved and with no knuckle scrapping either!! ...lol The finished job looks far better too.
Here's a link to the type of gland that i always use on the bigger multi core SWA cables from say 120mm up.....http://solutions.3m.co.uk/pv_obj_cache/pv_obj_id_88677BDEB4A1198ADA9983ADD99D267176180100
This is not the only manufacturer, there are several, Raychem being one of them and the ones i normally stipulate
For me it would be changing large motors. I once did a 36 hour shift changing a 250HP DC motor. 30 separate lifts with chain blocks to get the old one out and the new in. A few years later we’d got our act together, ripped the roof off and got a 120’ crane to do the donkeywork.
Reply to Most physical sparkying? in the Australia area at ElectriciansForums.net
In the mind of someone lying there wide awake at 3AM, just about anything.
