C
chid22
Hi all just looking for a little advise was recently working on a ventilation control and during the works noticed that the 4kw 400v motor was connected in star when clearly the manufacturers instructions stated the motor should be in delta. After sorting the control I changed the motor connection to delta and it run with no problems.
However after a few weeks I have now been told by some one based on site that the motor will not run under load and the inverter is tripping out on over temperature.
My question Is would running a motor in star when under load damage the motor in any way? It was always my understanding when in a star configuration in a star/delta start up you generally get a lower current when in star. Wish I tested the motor now but never did.
As you can probably tell motors are not my strong point so any help much appreciated
