Motor control circuit | Page 2 | on ElectriciansForums
Discuss Motor control circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sweet thanks for the feedback guys wasnt 100% sure about the jog switch but if thats all good I'll add in the C2 latch and should be fine
Also mate, on the White & Blue LEDs, as @Rocboni has stated, you don't need the NC contacts.
Another thing, why then E-Stop button? There is no mention of this in the question.
@Jacob1995
Hi, Welcome to the forum.
If this is indeed course work which does seem to be the case given how you presented the question then we are limited with the help we can give you, we do not condone direct answers been given as this will not help you learn and also allows you to avoid the usual route of discussing it with your tutor who will then identify any areas they need to go over with you.
We do in fact have an area specifically for trainees where we have selected members who can help you and aid you but done so that you are not receiving direct answers, if this interests you then please fill out the application for the trainee forum, we will need you full details and course details so we can assess your application.
If this does not interest you then please keep in mind when posting in future that we do not allow members to do your homework/coursework for you, I see in this thread that this is not the case and you were asked to draft up a drawing for scrutiny which is acceptable as it shows you are doing the work yourself and just asking for opinions rather than how to do it.
Reply to Motor control circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
