Motor controller needed... | on ElectriciansForums
Discuss Motor controller needed... in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi there. I have a motor that used to be attached to a milling machine, then it wasn't, then all the bits got lost, now I'd like to reconnect it but I'll have to wire it up again.
I'm perfectly happy with the wiring and logic, but I have no idea how to spec a controller. It's an x feed motor so I assume it's a steeper, it's direct connect to the worm gear and has an integral gearbox.
The only markings on the motor are: ZYT-150. 150W DC-230V 0.9A RPM4000 Class E.
Could someone please suggest a suitable motor driver that would provide variable speed, reverse (although I could wire that) and 1 or 2 limiter lines.
Many thanks.
If it has only 2 power wires or terminals, I suspect it is a permanent magnet dc motor.
Yes, it is a dc motor. If you want to run it forwards and backwards, you need a 4 quadrant dc drive.
So this is a simple feed drive with no requirement for rapid starting / stopping / braking / positioning, yes? It just has to run at a moderately constant speed set on the controller? There is no feedback device (tachogenerator or encoder) it just relies on a bit of IR compensation and the motor voltage for speed stability?
I was thinking it was a cnc axis motor on a simple machine, but @Lucien Nunes may have hit the nail on the head and it is Simpley to feed one way or another.
We have used the Sprint 4Q drives in a servo application, but they seem only to offer 1Q (basically speed control) and 4Q (both directions, motoring and generating as they brake and regenerate energy). For example a 1Q drive:
The non-isolated version is cheaper, but then your speed control and stop/limit signal MUST BE TREATED AS LIVE. For example:
And if you want four quadrant control:
Thanks for getting back to me.
But this seems a bit overkill. This isn't a cnc application, it's an old manual mill, the motor is from the old auto feed which was about as basic as it comes. The multipole switch died and I couldn't find a replacement anywhere that was anywhere near the same. This one switch handled input from the other buttons in the system as well as the limiters. I suppose this (at one point in time) was the cheaper way to handle the inputs.
There has to be a small board somewhere that can achieve this relatively simple task?
Reply to Motor controller needed... in the UK Electrical Forum area at ElectriciansForums.net
If you want to use the motor, you will need to get that thermal cutout working properly, and be certain it does! The little phosphor bronze...
  • -NikD-
  • Ireland
  • 18
  • 1K
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
