Maybe, but it would be sturdy.The question was how do you fix din rail inside an adaptable box, unistrut seems a bit extreme for that
Discuss Mounting DIN rail in boxes in the Electrical Engineering Chat area at ElectriciansForums.net
I used this method to keep the enclosure from the wall, makes an easy access SWA termination, allow SWAs, pyros, FPxoo to run underneath when there is limited space, and use any combination of screws / bolts to fit the dinrail to the enclusure and then an easy mount onto the unistrut.The question was how do you fix din rail inside an adaptable box, unistrut seems a bit extreme for that
Reply to Mounting DIN rail in boxes in the Electrical Engineering Chat area at ElectriciansForums.net
