Mounting Inverter outside | on ElectriciansForums
Discuss Mounting Inverter outside in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
sorry to cut in on u 2 but as your respected members can u advise !! fitted 16 sanyo 240 hit se10 with 3800 sunnyboy (i no 4000tl is better) but client just emailed and said the best he been getting is 2.79kw on clear day? he said y isnt he getting nearer the 3680 its set for?? i presume its time of yr!! whats your thoughts PLEASE!
everything tested great!!! he just asked is that ok!! just want ur reasurance !! before i confirm time of yr !! as i read the compatabillity issue thread on sanyo/sma and thought NOOOOOOOOOOOOOOOOOO:( anyway he happy to see how it gets on so we will see!!
We've got a similar problem so looking to build something...
Ours is sheltered and will be stood on it own, looking at a large cross section (4 x 4 minimum) tanalised timber structure - very rural that will fit in with it's location, wpg best exterior grade ply (good country builders merchant will know what that is - don't ask Travis Perkins :) ) and bolted down to concrete slabs.
We're struggling to come up with any other solution.
We've seen it done before - here's an example - there was literally no where else to put it without building a brick wall!
[ElectriciansForums.net] Mounting Inverter outside
Thoughts ...
@lamp - photo please,
Though I'm not sure that a galvanised (once cut) frame will last any longer than 4x4 tanalised (I've got a 4 x 4 tanalised structure in my garden 25+ years old and still got another 20 years of life in it) . Stainless Steel maybe.
Strut should last at least as long as treated timber once the cut ends have been galv sprayed.
Plus a lot stronger. I usually drop a couple of ends 3ft into postcrete and then build a frame up off that.
Will get some piccy's next ground mount job I do (wall mount inverter but will be a lot of tray run on strut posts)
Just thought it through, we've got a few lengths of S/S tray in the yard, I'm going to get them to make up a frame using that tomorrow and see how it works.
It'll be strong by the time I'm finished! - It's just a small Power-one PVI 3,6-TL-OUTD , so doesn't weigh near as much as an SMA SB 4000TL-20 :)
Reply to Mounting Inverter outside in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
