B
babba
I was going to say superglue or runaway, never seen it myself but some good replys on here..
Need to ensure you've got square cuts on the conduit! I guess need at least 150mm long screws, longer if insulation greater than 75mm!I have seen it done like this on several jobs (insulation on top of rafters), mainly barn conversions and the like. It isn' a particularly good idea IMHO but thats by the by, we used to drill a 20mm hole through the insulation to the rafter, and drop in a peice of 20mm conduit cut to the thickness of the insulation, then screw the brackets through the conduit and into the joists with sheradised screws.
Reply to the thread, titled "Mounting on top of insulation" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
