mounting systems for welsh slate roof
We're in a national park too, on slate roofs - agree with you about the tiled bungalows, urban installers don't know they're born ;-). Our roofer just takes the slate out fixes the hook and flashes it all back in with lead. None of it a problem just more time consuming and a bit of extra cost for lead and replacement slates. The only problem we've had was with cambrian slate which gave us problems with the hooks and flashing it back in. I wouldn't expect you to be having problems with leaking after such a short period, it's after a few years of the slate moving with the wind that the leaks wil appear and need to be resolved. None of our customers would let us near their homes if we were drilling through the slate.
You don't find many properties in urban locations where the builder has used pine trees as rafters which seems to be very common here specially in houses built just after the war :( As a family we've been installing solar products on our houses we have built since the 90s, no problems yet. Thankfully.
:cool:Time to share the photo's guys!
I've been trying to !
Well, I've been trying to post some images, and a link to a Unirac solution, but my posts are awaiting approval from a Moderator.
I assume it's because I'm a Newbie.
I don't really want to 'cheat' the system, I've PM'd Admin and hopefully my posts will arrive in due course.
In the meantime, if you go to Google Images and search for Unirac Two Piece Standoff and Flashing then you should see plenty of lovely pictures.
Jason has sorted out my posts.
If you go back to page 8 the images are there, and a couple of posts below that is a link to a pdf document concerning installation of the things.
Hi there, we have more than 1 MW of PV system installed (domestic, commercial) all over Europe and couple domestic in UK. Maybe it is not case in UK (temperature is not going below zero often), but when applying constant pressure on tile roof (even minimal), thermal expansions over time does the job. After several years slate tiles with hanger-bolts tends to not leak, but to crack. Also hanger-bolts tend to bend a little under panel weight (as I said, no snow in UK, maybe not the case), but even little is enough to create pressure. We had serious problems in mountain areas 2 years ago, had to remove panels and change mounting system and tiles. Hilti or K2 has got bracket mounting system for slate tile roof, check their pdf manuals, they have also mounting instructions there. Hanger bolts we use only for metal / aluminium roofs.
We've looked at many roofs lately with damaged, broken or completely missing slates or tiles. The residents had not even noticed so certainly no major leaks... Just wondering if the roofers are protecting their own interests somewhat...
Has anyone heard of the new building regs stating that you are no longer allowed to drill through the roof or was this just a bad rumour ive heard??
Not new regs, it's revised / expanded guidelines for the LABC, and is about to hit a series of right royal challenges (some justified, some not) that will see speedy retraction / rewrite.
What you you may be thinking of is the guidlines for screwing into rafters. Ironically there is a BS (5658 if I remember correctly) plus Eurocode that cover this.
The problem is that nearly all (except 2 that I know of) the roof hooks have come out of germany where the use of timber in the roofs is very different from ours, net effect if you use any of the 100+ roof hooks out there, you are not complying with the BS and Eurocodes, so are in breach of the Building Regs. Rather than give a solution, they have given an interpretation which says:
Distance from screw to edge of timber must be at least 4 x screw diameters
So that means that their is no way you can screw an 8 mm hanger bolt into a rafter unless it is at least 72mm wide!
Can i point you to building regulations BS5268-2 and you will find that hanger bolts will not probably meet the BS requirements + also i dont think any manufacturer will warranty 10 years using this product in slate + would you want to garrantee the EPDM rubber washer/mastic will last 10 years in welsh weather conditions?
Hey Worcester. As a side point whilst were on Building Regs, do you mind me asking which brackets and screws you would use for a trussed roof with concrete tiles with 35mm rafters?
Also does the local building control officer get involved in your installs or is it enough to be part of a cometent persons scheme?
