P
Piratepete
Hi Guys
If I move a domestic CU to a new position on an adjacent wall, what testing am I required to do?
The tails will be 0.5 metres longer, and each circuit will need to be disconnnected and then reconnected without any change to cable lengths.
Cheers
Pete :winkiss:
as a minimum, i would measure Ze, PFC, and Zs for each circuit, and global IR . obviously check/test the main bonding as well.
As above. If you change main tails/ main earth conductor, you are theoretically potentially changing the values in the tests Tel mentions.
Moving a Consumer Unit
Piratepete,
Pendle Electric,
