moving a socket 50cm!! | on ElectriciansForums
Discuss moving a socket 50cm!! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Customer wants a socket moved 50cm to the right.
The wall is brick with socket fed from below (floorboards), channelled into wall.
The 3 options I've given are:
1. Blanking plate on current socket and channel across. (cheapest option)
2. Take out cable from wall, under floorboards and channel up. (Best option but carpet has just been laid)
3. Take out cable, use skirting trunking that sits on carpet then channel up to new socket.
Just wanted to get peoples ideas really, see what the norm is as it must be a pretty common job?
Cheers all...
Cheers guys, I know option 2 is the best but its also taking up newly laid carpet, chopping into floorboards, relaying etc. Have given the customer the options, dont suppose there are any other options really?
Present socket sticks out too much (wardrobe slide door going there) whereas a blanking plate is thinner and may be ok, but would still look awful as i have said to her, but you have to give the cheaper options dont you.
Have basically said £35 for blanking plate option and £50 for floorboard option? About right?
personally, i'd leave existing socket there, even if it won't be used, and channel horizontally and fit new socket. blank plates look so naff if on display.
See above Tel!
Reply to moving a socket 50cm!! in the UK Electrical Forum area at ElectriciansForums.net
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
