moving a socket 50cm!! | Page 2 | on ElectriciansForums
Discuss moving a socket 50cm!! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Customer wants a socket moved 50cm to the right.
The wall is brick with socket fed from below (floorboards), channelled into wall.
The 3 options I've given are:
1. Blanking plate on current socket and channel across. (cheapest option)
2. Take out cable from wall, under floorboards and channel up. (Best option but carpet has just been laid)
3. Take out cable, use skirting trunking that sits on carpet then channel up to new socket.
Just wanted to get peoples ideas really, see what the norm is as it must be a pretty common job?
Cheers all...
Ended up giving the blanking plate option (decent chrome one) for £38 or under floorboards for £55, they went for the £55...... and I asked for the skirting to be kept up until I carry out the work! :D
Reply to moving a socket 50cm!! in the UK Electrical Forum area at ElectriciansForums.net
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
