Hi
I've been working for Domestic clients for some time and I'm considering branching out to do Industrial work. I'm faced with the fact I don't know what I don't know, if you get my drift, so I'm after some advice. What other qualifications would you suggest above and beyond the below list.
City and Guilds
2382 - Requirements for Electrical Installations BS7671 17th Edition of the Wiring Regulations 2008.
2393 - Building Regulations for Electrical Installations in Dwellings
2392 - Fundamental Inspection, Testing and Initial Verification
2394 - Initial Verfication and Certification of Electrical Installations
2395 - Periodic Inspection, Testing and Certification of Electrical Installations
Bizarrely in my experience it's a lot easier to get into industrial instrinent/electrical work than say become a scaffolder or rigger where there seems to be a legal requirement to be qualified. You may find going from domestic to an industrial maintenance role a fairly steep learning curve due to the variety of kit you will encounter. PLCs/valve actuators/motors/DC/HV/rotary converters
Industrial all day long.. You can actually take pride in the work you do without the fear of a supervisor up yer ---. If there's not a lot of industrial construction work then commercial follows suit.
I remember my time on industrial sites, you get the drawing from the office and get sent up to an area of the 4th floor then the apprentice can get the conduit/tray/metal trunking/drills/screws etc etc while you look things over.
you got drawings? :O lucky sod
Come on Terminal 4 doesn't look "that" bad.........
i think i seen a drawing once whilst i was at the distillery, quick walk round with supervisor at start of week, what annoyed me was when i first started he pointed to a brick and said "drill here", i drilled there and then he decides it doesnt look right, so we opt for where i was originally going to take my hole out, that said the only thing i found different about industrial work was the containment and type of cables, bit more manual intensive, i eventually got put into the switchrooms, suited me fine, smoking tabbies and glanding up 140 odd 2.5 swa/FP
Swicthrooms, I remember building them especially the hydraulic ones, the mains risers where always fun.
I always enjoyed PYRO though, but I am a strange one......
The skills you require cannot be had from any C&G course, you will have to learn them from others at the coal face.
The same would apply for an 'industrial' spark knocking plastered walls about. I wouldn't make a penny doing houses. I'd take 3 times longer then you would to rewire a house.
Lee I agree with your sentiments, but whatever happened to the term "ELECTRICIAN" electricians should be able to do all 3 of the so called competencies or they did when I was an Apprentice, sorry it is the 21st century I forgot, easy come easy train to be whatever you want as long as you attend the right course.:D:rolleyes::po_O:mad:, not having a dig at you mate just venting my frustration.
The OP was talking 12 months back, Pete.....might be an expert in all 3, by now.:)
I'm a offshore electrical technician and when it comes to house bashing I am not very confident , terminating cables is easy but routing cables and keeping it all the the regs is another thing.
It's all about experience mate. Find another sparky who is more industrial and try and get some time under his wing and he would be able to show you the ropes.
I'm going to spend my time off the vessels working with a mate who is a domestic spark, hopefully will be able to learn the domestic side of electrics
Derbyshire
Moving from Domestic to Industrial
Domestic Electrician Forum
Chris Hex,
Jacob atkin,
