Currently reading:
Moving into Alarms, Door Access and CCTV
Discuss Moving into Alarms, Door Access and CCTV in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
J
John Matrix
Hello lads. Just want to ask how much learning is involved with moving into Alarms, CCTV an Door Access. I’ve done a lot of Fire for Protec Fire Detection, both addressable and Conventional, Vespa- Cirrus Pro, a little bit on PA systems etc. I basically have limited installation experience on all of these. But understanding the fault finding, programming, commissioning etc, understanding the kit and panels etc I’m a little lost really. How long does it take to pick all this up? I really fancy moving into it.
Thanks in advance
Basic systems are so easy if you read the install drawings right.
Only gets more complicated when you need a laptop to programme systems but the makers of systems will do free or very cheap training days.
Reply to Moving into Alarms, Door Access and CCTV in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
