skay
Hi guys
I am on a job currently where a consumer unit has been extended and moved from one cupboard under the stairs to another cupboard under the stairs to make way for a new toilet.
Now the lady is having the meter and supply moved as well by edf, apparently you cannot have the main fuse under stairs below 4 metres. So the only option is to fit a flush meter box on the outside on external wall. We will have to buy the box chase the box, dig trench, etc. They will charge ÂŁ2000 + just to cutoff road and chuck cable and meter in.
Now the run from the new meter position outside to the consumer unit under the stairs is approximatly 4 metres.
My questions are:
Can I run 25mm double insulated tails through floorboards for 4 metres? Or does it need to 25mm SWA?
Would I need to fit a 100a Switched isolator in the new meter cupboard? Baring in mind it will be tight for space in there?
My questions are:
