Moving meter positions | on ElectriciansForums
Discuss Moving meter positions in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Maybe slightly confusing but here goes...
Have a job in a large building , the front is being used as a shop , the first and second floor as a living area , the supply into the building is 3 phase , with one phase being used to supply the shop, one phase being used to supply the living area and one phase unused .
the owner has decided to turn the large living area into two flats , she will need the current meter moving 20 meters to a communal hallway as well as another meter added in the same area to supply the second flat .
what steps do I need to take to ensure this is done correctly ?
Is it acceptable to have a meter 20 meters away from a cut out?
But then that leaves one supplier to supply the building. The landlord would then need to sub meter. What if one tenant wants to buy their electricity off EDF say and the other tenant from EON. That can't happen with only one supply into the building.
It's a three phase supply , could this not be split into 3 single phase meters ( one to supply shop and other two to supply two flats?
- - - Updated - - -
Then sub meters to which are accessible to tenants?
Yes but the DNO would need to carry that out as they will be giving you three separate supplies each with their own MPAN number. You quote the MPAN number when you arrange for the meters to be fitted by your electricity supplier. (EDF etc)
Reply to Moving meter positions in the UK Electrical Forum area at ElectriciansForums.net
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
