Moving socket to opposite wall. | on ElectriciansForums
Discuss Moving socket to opposite wall. in the UK Electrical Forum area at ElectriciansForums.net
Gl17 9AN
Have a double socket on one side of wall which needs to be on opposite wall 6m away. Can I swap out twin socket for a junction box/blank and then run twin an earth via trunking on top of skirting to new socket location?
Many Thanks,
A
You could, but it is not a very good way of doing things. Also if it is a twin socket (or more than one single socket) you would have to extend both cables from the original location to the new one(s), as a simple spur would need a 13A FCU to limit the max load.
To be honest if you are routing round skirting just for a pair of sockets you might as well leave the existing one there and just make up a long extension lead with 1.5mm flex.
Reply to Moving socket to opposite wall. in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
UK Strange
i think you're trying to do yourself some damage.... Plugtops are designed to be used with a fuse.... use it Plugging things in when the other...
