Moving switch fro one side of door to the other. | Page 2 | on ElectriciansForums
Discuss Moving switch fro one side of door to the other. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
in my humble opinion, fit an rcd fcu next to the board and run the lighting cable through it. these things are only £25 and it saves loads of hassle trying to work around the regs.....
Reply to Moving switch fro one side of door to the other. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
