MR WET PANTS IS NOW PLAYING AT BEING A SPARKY | Page 2 | on ElectriciansForums
Discuss MR WET PANTS IS NOW PLAYING AT BEING A SPARKY in the UK Electrical Forum area at ElectriciansForums.net
JOURNEYMAN
EPSOM
I received a call yesterday evening from one of my regular customers requesting that I attend a ground floor rental flat that he owns to check the electrical installation which had received yet another soaking as the flat above had another leak from a newly fitted bathroom. Apparently the ground floor flat bathroom light was flickering when in the off position and the bathroom extract fan was continuously running so I immediately called the ground floor tenant, instructed her to switch off the affected lighting and fan circuit via the mcb at the fuse board until I arrived later to check out the issues. This she duly did.
Shortly after my call however, the so called plumber who fitted the new bathroom in the flat above, turned up and stopped the leak and then went downstairs to the ground floor flat and told the tenant he could fix the electrics and supposedly "fixed" the flickering bathroom light and extract fan and left the circuit on declaring that it was now safe. He left no contact details, no paperwork to say what he had done nor used any test equipment to check cables etc.
As I live an hour from the property, I arrived unfortunately after he had gone and after catching up with the ground floor tenant on what had happened carried out checks on all of the lighting, accessories, extract fan, cables, etc. and any other electrical items within the vicinity and found the hall globe light full of water, hall and bathroom light switches soaking wet. Needless to say Mr. Wet Pants left the place in a worse condition and less safe than when he arrived.
I spent well over an hour checking everything was dry, tested and safe and before leaving I asked the tenant why she'd let the plumber carry out electrical works even though I was on my way, to which she replied that it said on the side of his van that he was a plumber and electrician and she thought he knew what he was doing as he reckoned he could fix the electrics! Unbelievable!
guy i work with dismantled and fitted a shower he thought was off, turns out it was live the whole time, his tester probe wasnt plugged in correctly, (i know not correct procedure blah blah should have used proving unit blah blah) but mistakes happen, and had he not had insulated tools that day i may have had to call an ambulance for him
may not need them , but it hardly looks professional
and youre honestly going to tell me youve never worked live before? ;)
I do work live with the appropriate training, PPE and tooling.
Why does it look unprofessional to use non-insulated tools?
Due to the annealing process of insulated tools they are more brittle and often fail a lot sooner that non-insulated tools. Financially it makes sense.
I select my tools appropriate to task and level of risk.
it just looks cheap imo, customers expect to see us with decent tools
i still see people cutting out backboxes with just a stanley knife, how long does that take vs a multitool/padsaw?!
My customers don't give a crap about my tools, they expect a good job at reasonable cost.
nothing wrong with a stanley knife on thermalites is there? although I bet you impress the customer more when you get the 6kg breaker out at lunch time to cut up your mars bar :D
sockets i'm doing at this time in a 1950's house.. engineering brick, them black in the miidle things, only thing that works is scutch on 110V makita, and even then takes 20 minutes to chop in a box.
while we're on the impressive tools, I heard they have a few of the tunnel boring machines they used on the thames super sewer going spare, could chop enough space for a thousand sockets in a moment
We have rows and rows of old Pit houses built with those bricks . Some of them are held in with lime . They are so hard it is easy to knock them into the cavity , if the house has one . They are definitely a challenge.
Reply to MR WET PANTS IS NOW PLAYING AT BEING A SPARKY in the UK Electrical Forum area at ElectriciansForums.net
People who claim to be plumbers... and tilers... New bath fitted and the drain is accessible from the side and there are isolating valves on the...
Typical! If they've used plasterboard screws in a bathroom they'll fail anyway they're not meant for wet areas. So I bet the wrong adhesive was...
    • Winner
