Multi function tester accuracy record template | on ElectriciansForums
Discuss Multi function tester accuracy record template in the UK Electrical Forum area at ElectriciansForums.net
This is what's supplied with the Kewtech FC2000:
[ElectriciansForums.net] Multi function tester accuracy record template
i can't be arsed any more. it works, it's good. spent too much of my life worrying if the meter is 1% out. never had all this crap with AVO 8 and wind-up Megger. needle points the right way, next job.
I’ve just started a new job, testing smoke extract systems (got the job through this forum as it happens).
Some of my instruments are suitable for the work, some aren’t.
I will also need to to purchase a battery tester, as the 2 I have don’t give a value for Amp Hour capacity, just a pass or fail.
The other instruments that I do have which I will be able to use are an old Amp clamp and a stand alone IR tester.
Seems I will have to get 3 instruments checked annually now to fill out the paperwork.
my local YESSS does 2 free calibration days each year. so in a 2 year span, i get 4 testers calibrated for nowt, and free coffee and a bacon bap each time. then an excuse to call at the pub on way home.
Reply to Multi function tester accuracy record template in the UK Electrical Forum area at ElectriciansForums.net
Hi I thought it was with amendment 2? Haven’t double checked.
