Multi Function Tester with low battery giving very low insulation resistance reading. | Page 2 | on ElectriciansForums
Discuss Multi Function Tester with low battery giving very low insulation resistance reading. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Re: Multi Function Tester with low battery giving very low insulation resistance read
I think you are confusing them with Ni-Cads as it's these that have the memory effect.
Ah - I thought it was both and only Li-ions didn't. Maybe I'll have a read around this...
If these MFTs start dishing out dodgy readings on low battery power, maybe they should just down once the batteries reach a certain level.
It'd make sure you've always got a new set to hand, if you were 3/4 through an I&T on a Friday afternoon!
Sounds like a good idea!
Reply to Multi Function Tester with low battery giving very low insulation resistance reading. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
