Multi RCD testing | Page 2 | on ElectriciansForums
Discuss Multi RCD testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
your sub-main cable would only require RCD protection if part of it was, for example, T/E from CU buried or partially buried in a wall without earthed metallic protection.
Mcb in the house as its a distribution circuit rated at the cables current capacity of the cable,
Supplying your db1 in which you have your rcd.
Not good to have two rcd's in series trying to see who has the fastest time lol
a fluc apacitor should dit it as long as it's charged to 500V and clipped to his goolies.
Reply to Multi RCD testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
