multifunction tester make? | Page 2 | on ElectriciansForums
Discuss multifunction tester make? in the Electrical Tools and Products area at ElectriciansForums.net
thanks think ill still go for that megger, with software its bit more but could always get the software at a later date
i did not bother with the software. i use formfill9 which is free on the net from castleline.com and fill that out onsite via my laptop. all this bluetooth takes far too long really, dont waste ur cash on it in my opinion.
i used to use the MI3000 and I can honestly say it was a great bit of kit. Done everything I needed, very easy to use and understand and quite tough. A cheap and cheerful meter that never let me down. One tip though, if you know your testing the next day, double check it's charged ;)
Reply to multifunction tester make? in the Electrical Tools and Products area at ElectriciansForums.net
Ok so just done a quick test on mine. Megger mft on high gives 0.30 Robin 4120dl on 20ohm hives 0.22 Robin 4120 on 200ohm gives 0.28 Bearing in...
Your meter has a 3 1/2 digit display, so the max. reading on the 200k range is 199.9k, so 32.7 reading is 32.7k. You interpret the meter reading...
2 3
