I want to talk about the context to this first, I'm in my first year at college studying level 2 electrical installation and for Christmas my family got me a toolkit which had some tools , multimeter and a soldering iron. They didn't really know much about things like that and they wanted it to be a surprise so the quality isn't so good, here is the exact tool kit: ZD-961_Tool Kit_Products_Ningbo Zhongdi Industry & Trade Co., Ltd. - http://www.china-zhongdi.com/product/291.html
Okay so I was messing around with the multimeter, turned it to AC voltage, and measured a socket to see if it works. It did, came up with 233v. Then I wanted to measure the amps in the socket, so I changed it to the 10A max , put the test leads inside and theres a big flash , big boom and black around the black test lead and the socket.
I then look at the multimeter, switch it to "20 DC voltage"and it shows a reading although nothing is plugged in , same for "AC volatage" and "Amps" so far the ohms setting is normal.
Now I think what I did wrong, the AMPS had a DC symbol next to and I tried to measure AC or/and the socket is over 10A.
Is there a way to fix my multimeter, or am I better off getting a new one?
Oh dear, that the end of that meter I think. Have you worked out why this has damaged the meter?
Lucky you didn't you didn't electrcute yourself tbh. Those meter are very cheap and certainly not rated for dealing with mains voltages, there barely worth bothering for Low voltage stuff
There CAT rating won't be good enough for dealing with mains voltages, the probe won't meet relevant standards either.
You also need to learn how to use multimeter properly you need to measure current in series with a load. When you've tries to tried to measure across the socket you've in effect shorted live and neutral hench the bang. A decent quality meter would have just blown it's fuse but as you've got a crappy meter it's fried.
When you measure voltage with a multimeter, the input resistance of the meter is very high - of the order of 1M ohm or more to avoid loading the circuit and causing voltage drop so you get an accurate measurement of the voltage as it would be without your meter connected. This means that a very small current flows and you don't get a big flash and bang when connecting across L and N or L and E.
When measuring current, the input resistance of the multimeter is very low - typically less than 1 ohm so you get an accurate reading of the current flowing in the circuit as it would be without your meter connected. Connect this across L and N (or E) on a typical 240v socket circuit and you will get a massive current flowing that will blow the fuse in the multimeter or, as it sounds in your case, will fry the multimeter.
As @StephenRowley said, you need to measure the current with a load connected and the multimeter in series with load.
At some point on your course you may cover test instruments and how to use them - I would hold off on any experiments at home until you have covered this and are happy with how to work safely.
This will defiantly be taught within your level 2 where series circuits having the same current and parallel circuits having same voltage and which instrument is used to measure.
In fact it will more then likely come up in your exam
Just goes to show, you should read the instructions! It would have told you DO NOT connect to mains in that mode.
With all due respect to the OP's family, I would put that lot straight in the bin!
At the very least never use it!
West Midlands
Multimeter showing reading when nothing is plugged in
Electrical Tools and Products
Klaudmjj,
Taylortwocities,
TrueNAS JBOD Storage Server
