perfect. bought it from car boot. £2. clamped tail at home, switched on 2kW oven. read 8.5A. spot on.Bet it still works tel.
Discuss Multimeter suggestions in the Electrical Tools and Products area at ElectriciansForums.net
it's a pain trying to measure Amps with a mutimeter. first isolate, disconnect conductors and connect to meter leads, then re-energise, measure current. then repeat procedure to reconnect.Why would you be pulling different meters out ?, are you measuring anything other than the usual Amps, Ohms & Volts ?.
No just the usual amps, ohms, volts
I think I need one that is over 1000v
Reply to Multimeter suggestions in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
