multimeter | on ElectriciansForums
Discuss multimeter in the Electrical Tools and Products area at ElectriciansForums.net
N
novernmunkee
hi guys i;m after a multimeter. i've looked at the kewtech kt117 and the dilog dl 9309.
any others worth a look? any body use the above mentioned?
thoughts comments, all welcomed.
thanks in advance.
Are you referring to a Multifunction Installation Test set, or a just a handheld mutlimeter for volts, ohms etc?
If your are after a multifunction tester then have a look at the thread "which is the best test Kit and Why", its been stickied at the top of this forum.
just like mine mate, AVO all the way. strill prefer my Model 7 though to these digital monstrosities
Reply to multimeter in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
