Multiple BT points...help.. | Page 2 | on ElectriciansForums
Discuss Multiple BT points...help.. in the UK Electrical Forum area at ElectriciansForums.net
Sussex
Evening chaps
I’m first fixing a new build this week large high spec 4 bed house.
The builder would like multiple bt points throughout the house what’s my best way of doing this as I’ve not done a lot of it.
Should I make one the main one then daisy chain off the rest like a radial?
If you run a radial between all the secondary’s, there’s a choice of two that can be the master.... one at each end.
kind of old fashioned having a load of phone points. I bet the homeowner ends up with DECT phones and a bunch of empty phone sockets
That’s a good point about being able to use either end of the radial and I agree about it being old fashioned, it must be an old guy architect who drew the plans up.
Suggest have a look around to see how BT has installed nearby properties. Make the master say the nearest to the road. Then radial out from there. Copper is going to be around for a very long time. I have just done a similar and used Cat5 as i carry it anyway.
cheers
P&S
cheers
P&S
'very long time' is a bit of a stretch when the current target is for the copper network to be taken out of service in between 5 and 7 years time.
If it were me I would run cat5e or 6 from a convenient central point (Where the master could be installed) with a view of installing a patch panel. These could then be used for telecom or anything else and youd just put the appropriate socket on the end. You could then have as many as you wanted and just ‘patch’ the relevant point into the panel when required.
You should wire 2 3 and 5 if you want the bells to ring. It is good practice to wire all six if using 3 pair cable to CW 1308.
There is no limit to the number of sockets you can wire in but the old rule was that the maximum REN of the phones plugged in should not exceed 4. REN is ringer equivalent number and used to be used when phones had 4 k ohm bells to limit the amount of current drawn from the exchange. With modern phones I do not really think it matters too much now.
Remember that you should use secondary sockets for everything except the Master which should be provided by BT or the line supplier.
A secondary socket does not have a ringing capacitor, opt out of service resistor or a lightening suppressor.
It is now only 2 & 5 that are used the wiring of terminal 3 is known to cause interference and affect ADSL broadband speed and bandwidth while older phones may need terminal 3 connected newer equipment does not. With multi pair cables it is actually better to connect any spare cores down to earth than connect them to the socket again to suppress interference that may affect the broadband
If BT fit an NTE5c+VDSL Mk4 filter it is possible to wire from the filter to an RJ11 extension socket or module for a VDSL hub / router to be located away from the NTE5c ( master ) socket at a more convenient location. It does away with having to fit filters at every extension phone position to prevent crashing the broadband
From past troubleshooting of poor broadband speed and bandwidth issues a lot can be attributed to extension wiring whether it is unnecessary connections, proximity to power cabling or other interference sources
Can't see the point in having multiple BT outlets these days. My last house had 8, only 1 was used, the master, and cordless phones and the router plugged in to the master.
I think cat5 is a far better idea if you are installing 4 sockets.
HA, HA, not a hope in hell. You can double that and still be hoping. There are not enough engineers in the world to do that, even if the money was available (which it isn't)
Actually, the master can be at any of the points. You can wire two wires into a standard punchdown terminal - so can run extensions off in two directions.
But as a late friend of mine was fond of saying, better looking at it than for it. It's easy to not use sockets that are there, it's "a lot harder" plugging into a socket you want to use that isn't there.
As already said, that's just pie in the sky thinking - not a snowball's chance in hell of it actually happening in that timescale. If they were serious about it, they've be pushing fibre right now - but as it is, they still have pricing (e.g. for FTTPoD, that's on demand) that seem designed to avoid anyone taking them up on it.
No. Current designs of filter plate split out the DSL signal before filtering the voice signal and splitting out the ringer line. So it's safe to wire pin 3.
Doesn't have to be those, many older designs also have terminals for the A&B wires. One way of doing it is to use (e.g.) the green/white pair for the DSL and link that pair behind the extension sockets until you get to the one where you want your modem - then you fit a BT+RJ11 socket and don't take the DSL signal any further.
At my parents house when I was still living there "some years ago" we added extension sockets (as well as more mains sockets, aerial etc) as we redecorated. I put a 201C box under the stairs, routed the incoming line down to it (honestly, the master socket moved all by itself :rolleyes:), and then radially wired out to the extensions. I put a filter on the master socket, and only ran an unfiltered line up to my back room where I had the router.
The NTE5 master HAS to be the first socket on the incoming line as removal of the lower part or in the newer NTE5c the front part of the socket isolates the extension wiring for testing of the incoming line. The base part of the socket is the test point for the incoming line
You report a fault to BT and they only want to know about the incoming line and not the extensions anything other than their standard wiring and you will pay for the engineer visit and any work to rectify the problem
Or given that multi pair cables are generally used you can use spare pairs for other uses
A lot of the ADSl filter plates are based on the design of the interstitial plates that became common when ADSL was first introduced with plug in filters they disconnected the ringing circuit to kill the interference that affected speed and bandwidth
As it is a new build I doubt BT will be fitting anything other than an NTE5c with or without a VDSL filter
In the days before the NTE5 that was standard BT wiring, once the NTE5 became the norm that all changed
I had fibre to the house installed yesterday and it works really well. However there is a box the fibre terminates into then a patch lead to the router both need a 13A socket and all the old copper has been retained as the exchange is not fibre ready for the telephone part of it. I am just glad that it is all in a cupboard and not in a corner of the living room. On that basis if I was wiring a new house now I would try and put the master socket in a cupboard.
Reply to Multiple BT points...help.. in the UK Electrical Forum area at ElectriciansForums.net
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
