Multiple cables in place of one | Page 2 | on ElectriciansForums
Discuss Multiple cables in place of one in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Under what (if any!) circumstances is it permitted to run two separate cables to make up the conductor surface area of a larger cable (which, in this case is impossible to install...
Need to change 2 6mm radials for a single 10mm, but it's going to be near enough impossible to draw through a new cable due to lack of access to the route....
Are there any loop holes in the regs which will allow me to use the existing cables?
Excuse what's probably a really stupid question, I mainly do temp installations these days... Festival sites etc, so never have to overthink access and making do with what's already there!
Reply to Multiple cables in place of one in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
