davesparks
Would the cpc not have sufficient surface area though with a16mm t/e with it only being 6mm
What does the adiabatic say?
Theoretically but it will be deeper than 50 mm
What size OCPD are you planning on using for the 4 x distribution circuits?
Do do you mean on each of the submain boards ?
The over current protective device that is protecting each 16mm T&E.
63amp each I was planning to use
63a 30ma rcd
