Multiple FCU on radial? | on ElectriciansForums
Discuss Multiple FCU on radial? in the UK Electrical Forum area at ElectriciansForums.net
Edinburgh
I have a 2.5mm supply in a loft and from this i have it going to a FCU which I then have my lighting mains for a switch coming from the load side of FCU , I then go from the FCU to 4 different sockets and then last in line I have to connect to another FCU for the bathroom heater downstairs , is this acceptable? (This would be a radial circuit as only one leg up from board for supply )
So long as it’s CPD is 20A and you meet disconnection times that sounds fine.
Pg 188 of the OSG refers - max CPD on a 2.5mm radial is 20A due to the cable only being rated to 27A.
NB - you said 'loft' in your OP which implies insulation, so check your derate factors as well!! It's 27A at method C, not buried throughout in itchy-scratchy stuff.
Reply to Multiple FCU on radial? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the advice.
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
