R
roukel01
Hello All
I came accross a 3 phase sub main the other day which was protected as follows:
50mm SWA Cable. From the main distribution board, a 200A MCCB. From there into a switch fuse isolator 200Amp general rated fuses.
From there clipped direct through a large storage shed into another iswitch fuse isolator , this time labled up to use 160Amp fuses. It then went into a busbar chamber, connected to a 3 phase kWh meter and then into another switch fuse isolator labeled to use 125amp fuses.
The sub main feeds nothing else along its run and is then terminated into a contol panel.
Although a little strange set up, is it ok? does it break any reg rules?
Cheers all
Cheers all
