Dannyspark
Hi All,
Any advice on this topic would be very much appreciated as I have hit a brick wall on this.
I am installing a Mechanical Ventilation System into a domestic property, which for those who don't know is basically a whole house ventilation system that takes out stale air and draws in fresh air.
My technical issue is this:
The system under normal operation is set to Low Fan speed, which it stays in permanently giving background ventilation. The client has also specified that he wants an automated boost facility for the bathrooms and kitchen, but doesn't want the nuisance of having to switch something over when he wants to take a shower.
As such I have installed Humidity sensor switches in the hot/wet areas, which when wired back to the Vent system need to kick it into high speed when the ambient humidity rises.
The fan motor is very basic and as such will not accept two seperate 230v signals at the same time i.e 230v to the low speed connection and 230v to the high speed connection without causing some strange annomalies probably as its causing a short I imagine.
What I require is some form of automatic switch device that interrupts the low speed phase connection when it receives power from the humidity sensor switch rediverting it to the high speed fan setting and then in turn switches back after the humidity sensor switch shuts off.
Any thoughts on appropriate equipement to do this as I have drawn a complete blank and this is the first ventilation system I have worked on?
Many thanks in advance chaps.
Danny
Danny
