You could link out all the zones apart from the one your using for exit entry that would eliminate the others.
Also is your exit entry a pir or contact ?
Is it programmed correctly for the type ? no resistor etc ?
hi thanks for your time i have programed all zones out only zone 1001 is programed as final with 30 seconds entry and exit its a pir detector but also tried a door contact also tried another circuit system is resister based with 2x 1k resisters sets and unset fine all was well before engineers code was lost so reset to factory set conditions and reprogramed the same as before .all points to entry time but its timed 30 seconds system will set and unset with this circuit 1001 programed out and other 5 circuits reinstated
Yes mate tried all the suggestions you've all tried to help and nothing
hi yes i agree its a final pir circuit with 30 seconds entry and exit programmed in no other detectors on route to rkp tried a different circuit with a door contact but does the same system was setting and unsetting fine till extra circuits required but no engineers code so reset to factory set conditions and reprogramed carn t find any programing faults for not unsetting without going into alarm unless resetting it has damaged it some way thanks for your time
Daciaduster24
United Kingdom
Business Name
PW Security and Electrical
My alarm panel is going into alarm when entering the premises
Security Alarms, Door Entry and CCTV (Public)
Cutepaul,
Pauly24,
TrueNAS JBOD Storage Server
