Yeah that the ones.... cracked a few over the years (use rubber washer if have to fit them these days)Its its the old plaster uplights / wall lights with the 2 holes in the back of the fitting to screw direct to the wall then I just use a right angle screwdriver
i know a lot of sparks hate fitting them but I have found over the years if you go easy and use a manual right angle screwdriver i have yet to crack one.Yeah that the ones.... cracked a few over the years (use rubber washer if have to fit them these days)
Think I just need a little more patience maybei know a lot of sparks hate fitting them but I have found over the years if you go easy and use a manual right angle screwdriver i have yet to crack one.
perfect thank you![]()
Edit Ealing Ceramic Wall Light
Uplighter in a white finishColour: WhiteMaterial: CeramicPower Source: Mains VoltageBulb Requirement: Max 40W Decorative Filament Small Screw Candle Bulb, sold separately.Guarantee: 5 years guarantee.Dimensions: Overall - H 135 x W 313 x D 150mmwww.editlighting.com
These you can just hang off of two fixings.
The up/down ones are better, you wire up the lampholder part and the plaster part just slots over the top.
Edit Bexley Up & Down Plaster Wall Light
Up & down light in a white finishColour: WhiteMaterial: PlasterPower Source: Mains VoltageBulb Requirement: Max 25W Decorative Filament Small Screw Candle Bulb, sold separately.Guarantee: 5 years guarantee.Dimensions: Overall - H 110 x W 310 x D 155mmwww.editlighting.com
Reply to the thread, titled "My favourite ! half moon plaster up light" which is posted in UK Electrical Forum on Electricians Forums.
