P
pablod
I have my first job so I can get signed off by one of the part p bodies. I need to know the best route to take for the isolation of the supply to the unit. I'm from Brentwood in Essex and wondering how easy it is to get the supplier to fit an isolation switch inplaceof the Henley block. And what it costsThanks
It seems the DNO's are reluctant to move on & improve standards. Industry standards are improved/changed & a new set of regulations are drawn up to reflect these, most are to improve safety & to ease/improve maintenance procedures.
About time DNO's had a rethink & brought they're practises back inline with a modern standards
is there actually anybody on here that knows what they are doing?
amateurs advising amateurs.if you really cant bring yourself to cut seal,(and by the way,if you cut one end close to the crimp and hammer a cable clip through whats left to open crimp back up it can be resealed with all markings intact),then try pulling the service fuse out slightly,usually there is enough slack on the seal to cut the power,wedge the fuse at this point and away ya go,ffs,this is called the electrician forum,though i doubt there are many on here.Im sorry to be so abrubt,but it seems to me that people these days get to call themselves electricians after doing a bit of "theory" work at college,or even worse,online,if you are so unsure then leave well alone.worse case scenario,cut the seal,reseal after with yellow crimp,cut the plastic off after crimping & sit back & wait for call from dno asking whos been tampering,heres a clue,you'll be waiting a long time.meter readers are just that now,health & safety dictates they can read a set of numbers & tap them into a machine,examining seals is beyond their remit.
Pull the fuse! Years ago i tried to replace a fusebox by removing the live tails to preserve the seal. I ended up in a confined space touching the live tail which belted me into the wall and could have killed me. As the Yanks say, you do the math
Might be an idea to mention having previously removed all load by way of the main switch or removing all fuses.
Well I'm pretty sure there are a few of us on here that know what they are doing, but I don't think I can add you as one of them.
Very classy the way you deal with resealing the fuse, and the safe isolation method, spot on.
When I want to be lectured by someone with your ineptitude I'll go to the house of commons. Son when I hang my overalls up at night, they know more about sparking than you do.
Where I work we often encounter old belmis panels which to cut a long and boring story short have the 3 phase fuses right at the very back of the board,often very stiff to remove.
Our procedure is to remove load(which you have to anyway to access),neoprene gauntlets,face shield and then remove.
I found one burnt out the other day and shorting directly to the panel,pulling around 300amps on start up then it tripped,you could hear the panel vibrating!!!
Scary stuff!!by using the gloves and face shield you do minimize the risk significantly.
Just a thought.
I once used to work with someone who whenever changing a DB and there was no isolator, he refused to cut the seals, so instead used to carefully remove each tail from the main switch in existing DB and tape them up
Ah. the old ways are the best. My first CU upgrade under the watchful eye of my old gaffer was done like this.:oops:
I take it you meant “Belmos”, I remember them of old. Not nice stuff at all! I was glad to see the back of it when we ripped it all out.
Yes,that's the ones Tony,bloody awful things,we've had a few blow up on the boys,horrible things all cased in metal with no way of seeing what's going on inside.
I had to change a contactor on my first nightshift weekend on my own,took a load of fault finding to get there and I couldn't for the life of me find how to isolate the 110v supply.
Donned the rubber gloves, dropped the sleeves and got it sorted.
I found out afterwards the 110v supply fuse is in the bottom of the cabinet and cuts the 110v to the whole unit!!!
Totally daft system.
i get a job done malcolm,no niceties involved.i happened to have worked with a lot of people,including one forum member that have taken so long thinking about a job that i have done it before they figure out a solution.my methods may not be ideal in this ridiculous world of h&s regs etc,but they get a job done.and as for for overalls knowing more about electricity than i do,do they have a scorch mark accross the chest ?i am guessing so the way you speak,probably more likeley a sweat stain from panicking at the thought of getting a tingle?walk into any barratts shoes,clintons cards,cardfair mor priceless anywhere in uk and your probably looking at my work,not to mention many major industrial estates/buildings.You are more than welcome to follow your procedures,but which of us gets the job done first ?
do you make cards and shoes aswell then
Is an electrician measured by the speed of install ?
Perhaps its the 3 o'clock at Epsom that is being discussed
If it is, dont aproach those hurdles too fast,its been known to throw jockeys on their backs
quote
Now that is more agreeable
Ahhhhhhhhh your a shop fitter, you have gone up 5 fold in my estimation, you reached the heights of a T+E jockey, I love the way you lads can throw a bit of T+E over a false ceiling, it is a joy to behold .............. and the way you use the click system and flex for the lights it reminds me of a Botticelli or is it just Botch.
You may have even progressed to using basket tray, is there no end to this.
I was totally wrong, the overalls are more qualified.
Nice one Malcolm.
GOTCHA! Splotts
PS Malcolm, when do the overalls go for their 17th :hurray:
I was waiting for the new amendments Tony to take effect mate.
The sad thing Tony is that we are leaving our industry in the hands of these lads, wedging a fuse, it is frightening
I would love to see him work on your stuff mate, you would be scraping him of the terminals.
I'd say just go ahead and pull the fuse. You've got to think about your own safety and whether you would feel comfortable removing the load side tails from the Henley blocks live.
Is that why shopfitters aren't seen working in heavy industry doing real electrical work,the ones that did have already been fried
Don't pull the fuse. If its your first one and you've never done it before. Its all well and good sayin turn everything off then pull but do you know about bitumen ? Look for it around the head and if its present don't pull the fuse because if that don't go back in your F***ED!!!
Reading this thread has settled my opinion: there are way too many apparent risks in pulling out an old fuse. I'm going to try to get the DNO to sort it out for me...
My first Consumer unit change
Australia
pablod,
Scrapper_Duncan,
