View the thread, titled "My first post and it's about LED lighting" which is posted in UK Electrical Forum on Electricians Forums.
I have a small utility room at the end of my garage, it have a fluorescent fitting for lighting controlled by an infra-red sensor. I decided to change it because the tubes and/or starters fall over at the most inconvenient namely winter time when it is dark.
I have changed the fitting to a standard bayonet type and fitted an LED light. My problem is that it starts ok but when the sensor times out it just dims and never goes out. I have tried low energy light and that works ok but looks like a candle when it starts. As we just walk into the utility for the fridge mainly it's always dim in there.
I have tried the LED in a normal wall switched room and it works fine. I have a martindale and that shows no faults though i am not sure that will pick up lighting faults.
Could there be a neutral fault ? though i cannot see why when a not light works ok.
Any help much appreciated.
you can have an incompatibilty issue with the sensor and the LED. try fitting 2 x 160k 2 watt resistors in series across the L and N.
The pir unit is electronic and not a relay type. Normally switching by Diacs wouldn`t be a problem when switching filament lamps. Leds can glow off the diacs leakage. If you remove the Lout and the glowing stops this proves the point.
answer is to buy a relay switched pir sensor, or fit a small contactor, relay. You could also try increasing the load, with another light fitting.
This is where my money is you always get a bit of leakage from the ssr buy a relay output PIR and bet the problem goes away
Reply to the thread, titled "My first post and it's about LED lighting" which is posted in UK Electrical Forum on Electricians Forums.
