View the thread, titled "My first post and it's about LED lighting" which is posted in UK Electrical Forum on Electricians Forums.
I have a small utility room at the end of my garage, it have a fluorescent fitting for lighting controlled by an infra-red sensor. I decided to change it because the tubes and/or starters fall over at the most inconvenient namely winter time when it is dark.
I have changed the fitting to a standard bayonet type and fitted an LED light. My problem is that it starts ok but when the sensor times out it just dims and never goes out. I have tried low energy light and that works ok but looks like a candle when it starts. As we just walk into the utility for the fridge mainly it's always dim in there.
I have tried the LED in a normal wall switched room and it works fine. I have a martindale and that shows no faults though i am not sure that will pick up lighting faults.
Could there be a neutral fault ? though i cannot see why when a not light works ok.
Any help much appreciated.
I didnt just dismiss the suggestions, i was looking into them and came across these light bulbs. The light is instant, stays on all the time your in there and shuts off after 60 secs when you leave.
Would just like to say thanks to all the suggestions above, they were very helpful, always good to come to a forum and get answers and this is a good forum will visit from time to time to help someone.
Reply to the thread, titled "My first post and it's about LED lighting" which is posted in UK Electrical Forum on Electricians Forums.
