My first soldering! | Page 3 | on ElectriciansForums
Discuss My first soldering! in the UK Electrical Forum area at ElectriciansForums.net
Elecmox
Europe
Let me show you my first soldering.
This is my first attempt:
This is my second attempt:
Please, be gentle. :)
I was practicing today desoldering (with a vacuum pump) and soldering on a PCB, but I have some problems, as you can imagine.
I was trying to desolder some components from a mouse PCB, but I couldn't make solder of component to liquefy in order to remove it with a pump. I have 30 watts soldering iron, and I suspect maybe it doesn't have enough temperature to desolder component.
This is the picture of PCB:
RED CIRCLE - Component (LED diode) that I couldn't desolder.
BLUE CIRCLE - Component (battery connector) that I desoldered, it's the same as in green circle.
GREEN CIRCLE - Component (battey connector) that I soldered, just to show is it good.
sometimes it's easier using a stiff toothbrush to remove the solder when you've melted it with a hot iron. mapply iron, then as the solder melts, brush away from the componemt leg. or try desoldering braid.
Should I use soldering iron with more then 30 watts?
depends on what you are working on. 30watt iron will cope with small components. some componebts and/or the pcb tracks will draw more heat from the iron , esp where heat sinks are involved.also, if you are using pliers to pull things out, the pliers themselves will draw heat and reduce the temp. of the joint.I use a 100watt weller gun for the larger work. but care needs to be taken not to overheat the joint and damage pcb tracks.
Sadly they cost more money, but what you really want is an iron that is temperature controlled, so it can be 50W or more but maintains the tip temperature at the correct value for soldering with less risk of damaging the PCB, components, etc.
For many, many years I have used the Weller 'Magnastat' type where you change the tip for both size and temperature setting, but these days you get adjustable ones for less cost. This sort of idea:
But you probably can find others for similar or cheaper prices.
and it is also worthwhile to note that a pair of narrow nosed pliers can be used as a heat sink to prevent damage to components when soldering/de-soldering.
Also, it sometimes makes things easier if you add a bit of fresh solder after you have removed as much as you can of the old stuff. Don't try to suck up too much in one go with the desolder pump, then you won't keep blocking it.
I plan to buy temperature controlled soldering iron in future, but for now I don't need it, current one is sufficient, it does ok job.
I will buy desoldering wick to see if it's better for smaller joints, I just couldn't desolder them with pump.
Solder wick is very useful. Beginners can sometimes pull PCs tracks off though so be careful.
[automerge]1593359129[/automerge]
Should have said PCBs but too late to edit it.
Reply to My first soldering! in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
