The lifespan really is a "how long is string" question. You seem well aware of the myriad factors that would affect this, and the decision of what to use is down to the electrician that installs them. Have you ever questioned the lifespan or thermal stress capability of a choc strip connector, a 20A junction box, or an insulated butt crimp ?
The MF logo is required by the regs to prove the enclosure has fulfilled the requirements of BS5377. It is to aid initial selection of the enclosure, or for identification of the enclosure if discovered at a later date.
So they are making these connectors without a rated lifetime. Then de-rating them for use in a MF situation so as to extend the lifespan, but they cannot tell us what the original lifespan was or what it will extend to when de-rated? How do they know that de-rating it is going to extend the lifespan? Why are they not producing connectors which will stand the test of time?
As far as connectors which already exist go they have bee around for a long time and we can all see from existing installations how they stand the test of time when properly installed.
What will that cable tie achieve though? Looking at the picture of them on the website you can see that the writing has already started to rub off of the cable ties, and that's the stock photo from the website! Really doesn't inspire any confidence in its longevity does it?
If discovered at a later date it is likely to have developed a layer of dust or whatever which will have covered the cable tie, and who is going to know what it all means? "instructions must be followed" isn't going to mean jack to anyone other than an electrician who wouldn't need to be told that anyway.
You do appear to have a bit of a downer on these connectors. Do you ask the same questions about crimps, solder connections etc etc before you use them for MF?
because all types of connectors have basically the same issues........
I don't have direct experience of the testing of these connectors but from my product testing experience I would say the following:
]So they are making these connectors without a rated lifetime. Then de-rating them for use in a MF situation so as to extend the lifespan, but they cannot tell us what the original lifespan was or what it will extend to when de-rated? How do they know that de-rating it is going to extend the lifespan?
They will originally have been designed for an expected lifetime. Then samples will have going through excellerated testing (temperature, humidity and vibration cycling while under maximum rated load probably) to prove that they meet the expected lifetime. I suspect the pass/fail criteria for this testing is the increase in resistance measured. That is for non-mf use.
Then they will have been considered for MF use. To pass the BS standard for MF use they would need to pass more rigorous testing. This will probably be a more extreme test cycle with a lower resistance increase limit to ensure that they will last long enough to be buried in the fabric of the building.
Obviously in the wago/line case (they are both the same spec I think) this additional testing found that the maximum current had to be reduced to meet the BS standard.
They are, they will have been proved to meet the requirement at the specified (i.e. derated) current.
yes, badly from my experience :lol:
Nothing is perfect, not even a bit of cable will last for ever so the MF stamp doesn't say it is perfect, just acceptable for a specified lifetime. So what would you use that you think is better? Even crimps and soldering is not guaranteed for ever and I have examples of both failing in use.
All it achieves is ensuring the electrician that fitted it is meeting the regs. BS5733 and BS7671 (reg 526.3 vi) say that it must be MF marked. Other than that you are right, no-one will see it again so who cares.
I suspect line products introduced them just to get round the "but it isn't MF marked so is it really ok to be used?" type questions from customers.
hth. I should stress I have no connection with line or wago other than as a user of their products so all this is assumptions based on my experience of reliability testing products.
So they are making these connectors without a rated lifetime. Are they ? where did you get this from ? Then de-rating them for use in a MF situation so as to extend the lifespan, but they cannot tell us what the original lifespan was or what it will extend to when de-rated? What's the exact lifespan of any other electrcial connector according to the manufacturer ? How do they know that de-rating it is going to extend the lifespan? Why are they not producing connectors which will stand the test of time?
As far as connectors which already exist go they have bee around for a long time and we can all see from existing installations how they stand the test of time when properly installed. Then if the test of time is the only test you value, we will have to wait and see won't we ? Despite these connectors passing relevant standards before sale, the same as any other connector.
If discovered at a later date it is likely to have developed a layer of dust or whatever which will have covered the cable tie, and who is going to know what it all means? "instructions must be followed" isn't going to mean jack to anyone other than an electrician who wouldn't need to be told that anyway. This applies to all MF marked enclosures then doesnt it ?
Sure you're not trolling ?
Apologies if this has already been said, but I rang the chap at wago to ask ab it more about the maintenance free side of things and he mentioned that the wagobox juntion box is maintenance free (as long as it is used as stated with cable tie) but the wagobox-light junction box is not Maintenance free.
The reason for this is that it cost a great deal of money to test the Wagobox junction box so that it could be deemed MF and I believe that was a factor in not getting the light box tested.
Just thought I should mention that one of them is not MF as it doesn't seem to be widely publicised and could mean lots of NON-MF boxes tucked away under floorboards.
Maintenance free:
Not Maintenance free:
Maintenance free junction boxes must have the MF logo and possibly the BS number to which they are compliant. Since the line boxes do not have this marking on the body, in order to meet BS7671 the cable ties have this marking and since the maintenance free requirements are for the enclosure as a whole unit this complies.
I'm curious to know, if people use these MF boxes in inaccessible places like under floorboards, do they actually fit a cable tie to secure the lid? Apart from this marking, perhaps the box should require a tool to open it, but I'd suggest a tool has probably been used to lift the floorboard in the first place (or maybe that does not count)?
I use a cable tie every time I use them, be it under floors or accessible in lofts etc.
I guess technically you could argue that the void under a floorboard could be classed as an enclosure in its own right but maybe that is stretching things a bit :-)
Anyway, just think, it might be a plumber lifting the boards so anything that keeps him away from the electrics is a good thing! :lol:
(with apologies to any plumbers reading this......)
a couple of razor blades embedded in the box would be a good deterrent.
I have used some of Wago connectors and Wago boxes to extend final rings and they are maintenance free so can be hidden anywhere.
hint on t/e use needle nose pliers to hold sleeve over cpc before inserting to push fit conn [wago/line etc] stops this pesky problem
Wow over 2 years old post ;). Cannot say I have any issues pushing t/e into wago connectors, useful tip though.
My "Line/Wago" Products experience...
Electrical Tools and Products
1shortcircuit,
Dan,
