T
tamoshanter
Oh.... You will need to take it to a garage or an autoelectrician then, it sounds like you do have something draining it, the tests are quite simple but you do need some knowledge of how to test..
Also your terminal will spark when connecting if the inside light is on in the car, IE the door is open.
I hope this helps.
So is this potentially an easy fix for a garage or auto electrician
