my pet hate on jobs | Page 2 | on ElectriciansForums
Discuss my pet hate on jobs in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
my pet hate pulling floor boards up ,tell client dont go near those floor boards cause you might fall down them ,so next minute customer just about fell in , mrs customer please stick to one room only . trying to pull cables through ,with out dragging them has well .
and now you have pet in the mix has well ,ok where is the cat .
FFS the cat down the hole has well ,I start telling the customer try a get the cat out of the hole before I drill the floor boards down ,and why your at it looking for your cat under there ,you may has well stay down there has well.
Still a pain to find though if no cables showing... @telectrix good idea!
Not if you let it hang out,
[ElectriciansForums.net] my pet hate  on jobs
My pet hate as a customer is the trades person who's a miserable sod that always tuts, moans and complains a lot, have we ever met Buzz?
My plumber is like that. You’d think he’d never fitted a tap in a tight spot before. Still some of the crap us customers want fitting these days!
i use the yoozy boxes when ever it's required to have working sockets before plasterer gets in. usually in kitchens where freezers etc. need supply without trailing extension leads all over the house for the cat to trip over.
I can see the idea there, I was more referring to putting something in the boxes any good plasterer (and yes there are a few) cleans out the boxes if needed. I was always taught to coil cables up into the box.
once had a total rewire. customer ran a bit short of cash, so was left with kitchen completed but rest of house left as 1st fix for 6 months.called back then to complete. upstairs rfc good. downstairs rfc ...no end-end all 3. checked every socket connections, all good. then vagualy remembered fitting socket box on a certain wall in lounge. all plastered and papered. bosch metal detector finds back box. careful cut ot reveals box with 2 T/E tucked inside.
Hence the testing prior to energising had the same the other day with a buried box (on a radial) old metal detector out didn't make a fuss over it as all the other boxes were cleaned out.
Reply to my pet hate on jobs in the UK Electrical Forum area at ElectriciansForums.net
I guess my last post was even less direct than intended.
nicebutdim
N
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
