Hi all,
Was hoping to get some light shed on the particular cause to an issue we had last night.
Was woke at 2 in the morning by my partner saying none of the sockets were working. I went to the CU and the sockets MCB had tripped as well as the RCD.
Flicked them both back on, but the sockets ring remained unpowered, all of them, even with the MCB still on. Couldnt be bothered to try and fix at 2am, so switched it off and went to bed.
Next morning, still not working. So i removed the cover to see if there was a loose connection. Upon tightening up the connections, the sockets ring was fine, but the kitchen sockets were loose on the outgoing and the incoming for the shower was not even close to being tightened up.
I cant see how these would affect the sockets tripping on another MCB though so am inclined to write it off as a coincidence.
Having turned the sockets mcb off and on a few times, theyre working again, so am lead to believe we are looking at a faulty MCB?
As for the MCB and RCD tripping at the same time, is that an indicator of a short to earth?
Cheers in advance for any advice
Joe
Joe
