N.I.E prices | on ElectriciansForums
Discuss N.I.E prices in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
my electric bill says 14 pence per unit , i think 1 unit = 1kwh .to myself that means for every 4 amps per hour equals 14 pence am i right or on plannet mars... cheers for your knowledge,
I do believe some supply authorities will provide a digital power consumption unit that gives real time and average usage of your electrical consumption. They are wire free battery operated with clamp unit on the phase tail. Could be worth enquiring.
Just thinking back to college lessons, there's true power and apparent power which vary! Will have to get my notes out when fuz clears from the Xmas feasts! Not sure it's as variable with domestic supplys compared to some industrial premesis!
So there is 4 amps in 1 kwh??
You have to be a bit careful as you are mixing units.
As malcolm says an appliance with a power rating of 1kW will draw a current of just over 4 amps if it is operating at a potential of 230V, but you have said 1 kWh! A kilowatt hour is an amount of energy - A current of 4.35A at 230V switched on for an hour will use 1 kWh of energy.
TBH the two things, amps and kWh are not directly comparable, it's a bit like asking how many miles are in 30 miles per hour:)
Point taken!!!!!!
Well I got a power consumption device for crimbo, cost, power, carbon produced etc, and since 5:30 yesterday morning I've used ÂŁ2.35!
My costs are 12.04p per unit & a standing charge of 13.44p per day.
Better than a pair of slippers/socks. I thought I would get everone in the fmaily back by bringing back from Saudi an alarm clock that not only wakes you in the morning but is programmed to give you the 5 prayer calls during the day ...............all in the call to prayer, I'm wondering how long they will keep them;)
So should we start on boxing day a list of the useless presents we got!!, perhaps another thread Mods.
Reply to N.I.E prices in the Australia area at ElectriciansForums.net
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
