N.I.E prices | Page 2 | on ElectriciansForums
Discuss N.I.E prices in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
my electric bill says 14 pence per unit , i think 1 unit = 1kwh .to myself that means for every 4 amps per hour equals 14 pence am i right or on plannet mars... cheers for your knowledge,
You have to be a bit careful as you are mixing units.
As malcolm says an appliance with a power rating of 1kW will draw a current of just over 4 amps if it is operating at a potential of 230V, but you have said 1 kWh! A kilowatt hour is an amount of energy - A current of 4.35A at 230V switched on for an hour will use 1 kWh of energy.
TBH the two things, amps and kWh are not directly comparable, it's a bit like asking how many miles are in 30 miles per hour:)
Hi there sorry for being a bit stupid but if i am running a dehumidifier at 570 watts for an hour do you no how much that will cost me for the hour on NIE thanks davy
kWh is a unit of energy -you pay per unit of energy (units of energy vary in price depending on your provider)
570watts = 0.57kW
kWh = kW x hours, so 0.57kW x 1h = 0.57 kWh or units
If you are paying say14p per unit then your dehumidifier is costing you just over 7p per hour.
Hope that helps :)
570watts = 0.57kW
Hope that helps :)
Thanks very usefull :wacko:
I also had one of the Owl monitors connected to my home supply also for a while. As a unit they work very well, they're pretty user friendly, very easy to install etc. I actually wanted the Google unit but the Owl one was a lot cheaper where I am. It was wireless and linked to the computer to give consumption graphs etc. I was hoping to interest the 2 kids in it and ultimately get them saving power by switching off lights, ceiling fans and airconditioners when the left a room. It as an abstract failure in this respect, they ended up having competitions running around the house switching everything on to see who could get the biggest spike on the chart. I had a minor hissy fit and ripped it out eventually, it was depressing me.
Yep! Sounds like exactly the sort of thing my kids would do as well!!!
Reply to N.I.E prices in the Australia area at ElectriciansForums.net
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
