Name a cable please. | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Name a cable please. in the UK Electrical Forum area at ElectriciansForums.net
Marvo
Staff member
Mod
Mentor
Supporter
South Africa
I'm trying to find the UK name for a domestic installation cable. It has solid copper conductors for line and neutral which are insulated black and red (black red blue yellow if it's 4-core). It has a thinner CPC which is uninsulated and the outer hard PVC sheath has a layer of aluminium foil in it. The foil isn't used in terminating.
FP200 Gold
I've never seen it in brown + blue, always black and red and there's no cloth layer. Just the outer PVC sheath which is quite hard and it's integral foil wrap which, even though it's shown in the photo above as a layer on its own, I've never seen it come separate from the sheath. It just uses the standard cheap PVC glands with a compression ring in them. It's commonly used in smaller sizes like 1.5 and 2.5mm for general installation of final circuits but I've seen it as large as 10mm and it might even go a bit larger than that.
Thanks MJD. It's a round cable, not flat and it has no fire rating or special properties. It's not 'armoured' as such and wouldn't be considered to be penetration proof.
Consider yourself told off, now go and stand in the naughty corner Marv :grin:
Reply to Name a cable please. in the UK Electrical Forum area at ElectriciansForums.net
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
I suspect you are not competent to be undertaking these works.
    • Optimistic
    • Funny
4K
Recommended Sponsor News
Hi everyone,
