Name & age of this fuse box?? | Page 2 | on ElectriciansForums
Discuss Name & age of this fuse box?? in the Australia area at ElectriciansForums.net
O
Octopus
Being doing a PIR today and came across this beauty - can somebody help me with its model/age etc?
I particularly liked the fact that there wasn't an earth bar and the earths had been twisted together, outside the CU and pushed into a choc block! Its a TNS system without an earth too, plus a partial rewire about 40 years ago has left a combination of rubber and PVC cabling too! [ElectriciansForums.net] Name & age of this fuse box??
Well lookin on the brite side.....Is it a fairly large place murdoch as i noticed that the c/u has a good row of carriers which for the date of this thing i would have thought suggested a larger install (for the times)?.........:tounge_smile:
Sadly not a big place, 3 of the fuses are no longer required, but the garage is "hanging" off on of the rings and the EFLI result was rubbish! So maybe a high integrity board!
Its the fuse carriers and the general state of that board though des.......
Yes,only joking Glen
Having said that,it is not as bad as many I have seen and worked on,by a long way
It doesn't look home made to me,I believe there used to be a lid on these with hinges on the left,when closed the isolator was still accessable
The ceramic fuses and holders often cracked or the fuses would be split in half, with just the wire holding them together,so in that respect it has lasted well,also there doesn't appear to be any overheating apparent and the cable ends look sound,could do with a facelift though
LOL!! a spot of sanding down and a varnish should do it. A little dab of paint (red Blue) etc on the fuse carriers and jobs a gud un..,,,,,,,,,
I just removed one from a outside toilet had 4 ways eg fuses of the type above and the wooden box as des describes lol looked like a chest set box lol but better made
I've recently took out something similar which was from house built around 1965. I thought it was 1940's, but talking to the next door neighbour, he said they were all like it from new, and built between 63 and 66.
I always thought the ceramic carriers had gone a lot earlier, but it appears not - it's like houses built in the late 90's still had rewireable fuses, rather than RCD protected with MCBs -there are lots of houses like that here (Leicester), probably as a cost cutting measure, as I know I fitted RCD CUs from 1996, and they were around before then.
Reply to Name & age of this fuse box?? in the Australia area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
