Search the forum,
Discuss Napit Fast test EICR form query in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
KevinH
Has anyone on here using the Napit Fast test software for EICR's noticed that in the section "Extent and Limitations of Inspection and Testing" there is a box marked "Extent of Termination Sampling" which needs to be filled in.
This must be a very recent addition, or it's been longer than I thought since last doing an EICR, but what goes in the box?
I'm assuming it must mean 'how many accessories have you removed to check the terminations' i.e a percentage?
I typically go for 30%, but is this what they are asking?
Cheers.
I kinda used logic and assumed that's what they meant, but still good to get a second opinion
No worries, they only put in on there when they changed the forms when AMD2 came into force.
Reply to Napit Fast test EICR form query in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Had an enquiry where the installation (commercial) is relatively new and client has requested a condition report. Probably 80-100 circuits plus...
I've started to move over to AMD 2 forms for my CU installs, if only because the schedule is so much easier to tick and I can stop sticking labels...
Eh up :) I've done some new PDF forms for BS7671 18th Edition Amendment 2 2022 (the Big Brown Book), based on the IET model forms. You can fill...
12K
This is slightly pedantic, so right up my street. I'm filling out an EICR. The sockets are wired in 2.5 (apart from some in the kitchen that have...
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
13K
