Need 2nd opinion on cable....... | on ElectriciansForums
Discuss Need 2nd opinion on cable....... in the UK Electrical Forum area at ElectriciansForums.net
G
Guest55
this has been bugging me for weeks..........
been using Fp200 for all socket / lighting circuits on current project , the usual 1.5/2.5 stuff
and im almost sure , but not 100% , that the tinned solid core cpc is the same size as the L / N ??
its certainly not a 1mm earth in the 1.5 cable......
had a quick nosey on a cable website but found nowt conclusive.
anyone else confirm or know different ?
thanks ian but still doesnt mention cpc size like the other cable website i checked.
i can only deduce that the cpc is the same csa as line as a reduced size would need to be noted in the manuf. data.
something needs to be recorded on the cert for earth size so im going with my gut.
Can't you measure the diameter with a vernier and manually calc the CSA?
nope , got no verniers..........
but i could measure resistance on a spare piece - if E csa = L csa , then L-N & L-E should be the same on a continuity test :)
i just thought someone may have come across the same issue previously , especially when the time comes to fill in cert and youre not on site lol.
I haven't seen a similar question so they've probably just made a wild guess :)
The resistance method would be pretty accurate especially if you have a longish piece of cable you could also size it using reference tables for copper wire resis/meter.
Reply to Need 2nd opinion on cable....... in the UK Electrical Forum area at ElectriciansForums.net
