Need a Digital Meter to read the Units used | on ElectriciansForums
Discuss Need a Digital Meter to read the Units used in the Australia area at ElectriciansForums.net
Hi guys anyone got any links to suppliers of Digital Unit counters. Going to be using for a shop, so they can work out
how much juice they gotta pay landlord. as there another CU feeding a flat on same supply.
Shop CU is separate from Flat just fed from same source
OK going to answer my own question. LOL Just remembered worked for guy who had a sideline in slot meters, though i would give him try. He's in South London, and yes he still does, but now all forms of digital meters, single phase 3 phase, card swipe meters, micro meters and all sorts. He s real sound VERY reasonable and deliverys all over country and europe..
So if you ever need hear he is
Electric Slot Meters (London), Wimbledon, Merton, SW19 2QN - Contact Details | iLondon
Reply to Need a Digital Meter to read the Units used in the Australia area at ElectriciansForums.net
if the 3 spaces with charge points are always allocated to the same 3 flats, surely the easiest way is to run the supply to the load side of the...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
