Discuss Need a little help, can I add a second PIR with a single core line in (live) in the Lighting Forum area at ElectriciansForums.net
Welcome to the forum mate.
Theoretically, your diagram will work.
What cable you thinking of using?
So you show the outputs from the PIRs are linked, so all the LED lights will come on if either PIR is activated. Is this what you are after?
I would send a three core around from the left PIR to the right one picking up the lights and use the spare as live feed and defo ditch the double connection at the CU...Will this work?View attachment 105861
Reply to Need a little help, can I add a second PIR with a single core line in (live) in the Lighting Forum area at ElectriciansForums.net
