Install the app
How to install the app on iOS
If you have electrical work available, then you are in the correct forum.
Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
I am requiring a 12Vdc Relay that is normally closed, but I also require the relay to delay before returning to closed position (when de-energised).
Are there relays on market that do all this combined or do I require a seperate time delay module of some kind?
With a relay if you cut the power to the relay you cannot maintain the contacts open for a specific period of time because there is now no power to the relay.
There are off delay relays that have a control signal in coming and when that stops (even though the power to the relay is maintained) the relay will switch after a set time. If the power to these relays is cut then the contact will switch instantly.
You can get some that will hold open even when all the power is removed. However these are expensive and only really offer a couple of seconds worth of delay maximum. It just uses a capacitor.
Get a little programmable controller.
An Omron Zen should do the function of that you request. You can programme it with the keypad buttons too. Quick and easy!!
A perminant float trickle charger to install on a small 4kw diesel backup generator behind a customers house (still in design stage). But here lies 2 problems I see to over come. (1)Having a way of seperating the charger output from the battery termainals when engine running so the diodes don't get fried by the alternator on the engine or both. (2)When the power to the house and charger input is cut, I want to do the same again so charger does not risk draining battery down.
(2) I initially thought a 230V relay normally open - solenoid feed in parallel with charger input, so charger and battery only connected when chargers 230v input is present.
(1) A 12V relay normally closed (charger and battery connected in dormant state) then a switch feed from emergency stop button when pulled out to open relay prior to engine startup. But here I have come stuck because I realised that when you want to stop engine by pressing stop button in, the relay will close instantly but the alternator will still deliver 14v charge potential during engines gracefull shut down.
Here its where I am exploring potencials of time delay so the relay does not close instantly, but for about 10 seconds or so.
You could have a transistor driving the relay coil and have a suitable size capacitor in its base circuit, so the charge leaks away slowly before it switches. If you are into designing that sort of stuff.
The Schneider re17 series might do what you need, I think you need a 'C' type timing function but may need to go for a multifunction unit to get the 12V operation. It would be a lot simpler if you could use 24V
Going back some years we also used a type that were 'slugged'. They had a thick iron sleeve over the coil that used to hold them in via residual magnetic field for a short period when power was removed. Not sure if they still make them though, last time I saw them was late 70's, early 80's.
Yes this sounds completely unnecessary. Unless it is of a peculiar design, there's no need to disconnect the charger when the alternator is running. The only reason you might want to disconnect it is if it has a battery status meter on the output that would discharge the batt when neither mains nor generator power are available for a day or two. Many take zero current when off and can be left permanently connected without fear of discharging the battery.
You mention both float and trickle charging, these are opposites in that float is constant voltage and trickle is constant current. Float or multi-stage terminating in float is what you need for permanent maintenance of charge in a modern lead acid.
FWIW on a DC relay, a suitably sized electrolytic across the coil will hold it for a few seconds, but add a series resistor to limit the inrush when the control circuit closes and charges the capacitor. The relay contacts may have to be derated when slugging because the operation is not as swift.
Reply to Need a specific relay - If exists??? in the Electricians Jobs area at ElectriciansForums.net
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes.
We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world.
Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
